Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
612 Perguntas Visualizar todos
Top Left side Overheating MBA Early 2016
MBA 2016 gets heated on the top left side. And loud fan noise is audible. After that, the system slows, hangs and restarts automatically. This happens after every week or so of doing 3 hours web browsing daily. This is happening for the last 3-4 months. I always put it to sleep. There are 50-100 tabs opened at all times on both Chrome and Safari.
Esta é uma boa pergunta?
Pontuação 0
4 comentários:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adicionar imagens a uma pergunta já existente
por
Unable to take screenshot. So just posting the results here:
Cycle Count: 631
Battery Status: Good
Battery Temp: 35.3 C (currently charging at 32%)
Charging with : 23 Watts
Power Adapter: Connected
por
@Kunal Jain - What is the batteries manufacture date?
por
It's May 2016
por
Adicionar um comentário
1 resposta
While we often point people to count the cycles as most folks run their battery hard, its not the only measure, Age is also a factor! Given its age I'm sure this is the original battery! Batteries only last for three to four years as the chemistry breaks down.
The left side is where the charger connects the MagSafe connector can often heat up (warm) as the power feeding though it has enough resistance, but a weak battery also demands more power pushes things getting it very warm!
So to fix things you need to make sure the MagSafe connector interface is clean as a dirty connector can make things worse. You may need to replace it if it's become warped. MacBook Air 13" (Mid 2013-2017) I/O Board and he's the guide MacBook Air 13" Early 2015 I/O Board Replacement
But even that is not enough! You need to also replace the battery too! MacBook Air 13" (Late 2010-2017) Battery
Imagem de MacBook Air 13" (Mid 2013-2017) I/O Board
Produto
$79.99
Imagem de MacBook Air 13" (Late 2010-2017) Battery
Produto
$59.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kunal Jain será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 27
