Ir para o conteúdo principal
The Apple Watch Ultra with its 49 mm case seems like a roided out Apple Watch. It was announced on September 7th, released on September 23, 2022, and is the first Apple Watch certified MIL-STD 810H and EN13319. It features a customizable Action button and L1 and L5 GPS.
What is the Battery volume?
I want to compare with S7 battery volume to see if the batt really is another tech
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Pergunta mais útil
Hi, the dimensions of the battery are approximately: 4.7 x 29.2 x 25.4 mm
You can also check out Apple Watch Ultra Battery Replacement for more info.
Esta resposta foi útil?
Pontuação 5
2 comentários:
Great, thank you! Same efficiency!
por
@Albert Cor - Energy density is more a factor of chemistry for the given physical space (volume).
Right now we are at a plateau, the current Lithium Ion battery chemistry is the densest we have.
por
According to the iFixit page for the Apple Watch Ultra, it is a 542 mAh / 2.07 Wh battery
Pontuação 4
3 comentários:
I wasn't asking about capacity, but volume. Are they able to put more capacity in less volume?
por
What do you mean by volume? Like physical volume?
por
@jmehnert Yes, thank you!
por
Smart watch not charging
Pontuação 1
The smart watch is not charging
Pontuação 0
Adicionar a sua resposta
Albert Cor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 712
