Ir para o conteúdo principal
Left joystick continues outputting forward or back motion after flick
I have an Xbox One 1708 controller. It's worked great over the years, and I've taken good care of it. It lives in a pouch in my laptop bag when I'm not using it. It may have been dropped once or twice, but I've never noticed any issues after those few incidents.
After some months of not playing rocket league (all I use the controller for) I recently got into it again and noticed after I flicked the left stick up or down (forward / backward), It would continue inputting movement in that direction as if it was pinned there. This is only the case for up/down movements, left/right movements are fine. If I move the stick in the opposite direction of the ghost movement, it will respond to my control again.
What do you guys think? Does it just need a good cleaning or am I due for some repairs / a new controller?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Stick drift. You need to replace the stick module on the circuit board. Easy enough if you're confident soldering. If not a computer shop should be able to replace it.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I'm great with soldering. I may need to get a finer tip for mine though as I don't think it's small enough for this task. Any recommendations on where to pick up some new joystick modules?
por
I buy mine from ebay normally
por
Adicionar a sua resposta
Paulo Mello será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 21
Duração total: 157
