Ir para o conteúdo principal
The Meta Quest 2 (formerly Oculus Quest 2) was released in October 2020 and is the successor to the Oculus Quest.
Audio cable replacement oculus 2
My son is broken or south of wires on one side of us VR headset oculus two VR headset and I was wondering if there’s a way to repair that
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Shawna Bandmann post some good pictures of where the cable is damaged etc. Let's see if that is fixable since replacements are hard to come by. Go to Edit your QUESTION and use this guide to add images Adicionar imagens a uma pergunta já existente
por
Adicionar um comentário
1 resposta
Hello. If you opened your unit, there is no warranty anymore, so to solve this you'll need to get a Quest 2 for parts and harvest the cable from it. You can also check on eBay, but parts are few and far between since they were never sold separately. If you have a warranty contact Meta.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Shawna Bandmann será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 86
