Ir para o conteúdo principal
Second generation desktop trackpad released by Apple on October 14, 2015. Model A1535.
I have a Magic Trackpad 2 with a swelling lithium battery
Is there a replacement battery available for the Lithium Ion battery in my Magic Trackpad 2?
I recognize that this swelling is a potential fire hazard.
Further information: The battery is a TIS 2217-2548 Apple South Asia (Thailand) Limited Product, Lithium Ion Polymer Battery
Another question: Will the Magic Trackpad 2 operate with the battery disconnected or removed as long as it is plugged into my MacBook system?
Esta é uma boa pergunta?
Pontuação 13
8 comentários
My Magic TrackPad 2 Lithium Ion Polymer battery swelled to the point where it detached the bottom plate of the unit!
I decide to remove the battery from the unit. I detached the plug unit from the circuit board and the bottom plate was free A little glue softener allowed the three patches of double stick tap holding the battery to a black aluminized heat sink on the bottom plate to detach and the battery is free.
When I put the bottom plate back on (without a battery) and plugged it in to my keyboard. It works perfectly with the exception that I am getting a low battery symbol beside the Bluetooth rune on dashboard.
if you "carefully" remove the lithium ion polymer ion Battery from your Magic Trackpad 2 you can go on using it just not as a stand alone wireless device. Why Apple saw the need to do away with the 2 AA batteries in the old Trackpad for the lithium ion polymer battery is beyond me
Anybody have source for a replacement for a TIS 2217-2548 3.78Vdc 2024mAh battery in the USA
por
I took the battery out with no issue, but the function is not the same. There had been a clicking motion that is not gone after removal of the battery and its hard to select in right click from the menu. Perhaps I did not put the parts back together, but I thought it was pretty simple.
por
So the forcetouch is disabled without the battery. I might have been nice to say that as a warning.
por
@davidgruenberg ye, I found it today. I checked twice, if battery removed, taptic engine not working via cable without battery. A little upset about this. But the battery was so swollen that the back cover partially fell off, and the trackpad wobbled)))
por
I know the Magic Keyboard of the same era works without a battery, if kept plugged in with a lightning cable, so I'd expect the trackpad too as well.
por
Exibir mais 3 comentários
Adicionar um comentário
7 respostas
Solução escolhida
You can get a battery for the Magic Trackpad 2, but I have only been able to find listings on AliExpress, or similar so I cannot speak to the reliability of these parts.
As for whether it can run on USB cable alone, with no battery, I’m not sure. I’ve honestly never tried. It logically makes sense that it would. But my logic is by no means infallible.
Esta resposta foi útil?
Pontuação 9
7 comentários:
^ What they said. On small devices it's a crapshoot whether it will work without a battery or not. You'd think that sensible design practices would say it should be able to work on AC power or battery for anything that incorporates charging, but I have a few things that have proved that's not always the case.
My electric shaver, for example, won't run if the battery is dead, even when it's plugged in to the outlet; not until it's charged enough that the battery can run the motor.
por
@dadibrokeit ^ What she they said. Please and thank you. :)
And yes. It's nonsense sometimes what will run straight off the wall adapter, with no battery, and what won't.
por
Ah, my apologies. Corrected now.
por
@dadibrokeit I get it. Pronouns are a weird thing. And not readily obvious.
Although, honestly, I appreciate that you used she/her… which sounds weird given that I have eschewed “feminine” signifiers being used for myself. But I get “bro” and “man” so often in repair spaces that I almost just let it slide. So many people affiliate repair knowledge with “masculinity” and it was nice to see that isn’t always the case </rant about my gender and not so vaguely misogynistic trends in repair spaces>.
por
@ftl Nobody got derailed; we had a side conversation in the middle of it.
por
Exibir mais 2 comentários
My Magic TrackPad 2 Lithium Ion Polymer battery swelled to the point where it detached the bottom polymer (styrene?) plate of the unit!
Before the battery bag slits and the battery possibly catches fire I decide to remove it form the unit. I detached the plug unit from the circuit board and the bottom plate was free A little glue softener allowed the three patches of double stick tap holding the battery to a black aluminized heat sink on the bottom plate to detach and the battery is free.
I discovered an interesting thing about the trackpad2 when I put the bottom plate back on (without a battery) and plugged it in to my keyboard. It works perfectly with the exception that I am getting a low battery symbol beside the Bluetooth rune on dashboard.
This means that if you are willing to "carefully" remove the lithium ion polymer ion Battery (time bomb) from your Magic Trackpad 2 you can go on using it as a plugin device just not as a stand alone wireless device. Why Apple saw the need to do away with the 2 AA batteries in the old Trackpad for the lithium ion polymer battery is beyond me (except perhaps that the engineers though it was cool).
Anybody got a source for a replacement for a TIS 2217-2548 3.78Vdc 2024mAh Apple Japan battery in the USA or at least short of the PRC gray market?
Pontuação 8
5 comentários:
Now, that's the kind of comment I've been looking for. Thank you, Richard!
This trackpad has been sitting here doing a good imitation of an opening clam, while I try to figure out some useful way of dealing with it, rather than taking it to hazardous waste.
Consensus seems to be that the battery isn't feasible to replace by any reasonable method. But, knowing that the unit will work without the battery, makes that project possibly worthwhile. We'll see 'what it looks like'/'what I think' once I have a moment to remove the battery.
I hate throwaway mentality...
And, thank you, Gwendolyn, for giving us some insights into what any adventures into the innards of this trackpad might entail...
Thank you!
por
Larry:
You are welcome!
Here is a q quick update:
I've been running the Magic Trackpad 2 without a battery since the battery pried open the styrene back panel by swelling and my original post.
The Lithium ion battery was relatively easy to remove with some tape adhesive solvent and once un-stuck simply unplugged. The trackpad back cover morphed back into its original shape with the swollen battery gone and the trackpad works perfectly except for displaying a dead battery symbol on the header. There is no reason to be afraid of a careful battery removal and doing so will save the unit from the recycling bin as long as it is used plugged in. Honestly I still prefer the AAA battery version of these devices. But of course they don't self destruct and need to be replaced.
Honestly I don't understand why Apple cannot either ditch lithium ion batteries or make them more easily replaceable?
I don't want to order a pig in a poke from AliExpress. Maybe IFixit Should source a battery replacement.
por
Hi,
the same issue happened to me as well with the battery (swollen and pushed the back out).
But now without the battery I don't have any click feedback. Everything apart the feedback is working ok!
I have connected the battery back and tested it, and the click feedback is working.
Obviously the expanded battery for one does not fit the device and of course there is a hazard of some injury as well I guess.
Do you have the click feedback on you pad without the battery?
por
I had the same problem of no click feedback after battery removal due to swelling. Out of a hunch I removed the cable and battery management PCB from the battery and plugged it back in (i.e. without the battery, of course). The haptic feedback works again!
por
Can confirm, I've removed the battery but kept the cable and battery management PCB and the haptic feedback works.
por
Like others here, my trackpad's battery swelled to the point of pushing open the backplate. I picked up the battery Patrik linked from AliExpress and performed the repair. The battery arrived in 25 days.
The backplate open:
A closeup of the two batteries for comparison:
I cleaned off the adhesive and installed the new battery. I clicked the backplate into place without adding more adhesive. The backplate stays in place on its own when sitting on a desk.
And, it connected without issue:
All features work.
Pontuação 4
2 comentários:
When I received the replacement battery linked above, it arrived totally unmarked or identified from what looked like Mr. Li. The battery initially looked far too long for the trackpad, but when I finally got around to getting the trackpad out for inspection, I was delighted to discover that the battery’s length was perfect, and indeed the cable and socket configuration appeared to be the same as the swollen one beneath the gaping wound in the trackpad.
The only thing that took any time was convincing the old battery’s adhesive to surrender. After placing new adhesive on the new battery, everything went back together quickly and effortlessly.
I knew that I preferred the trackpad to Apple’s curiously miserable Magic Mouse, but I wasn’t prepared for the sensual delight and ease of zipping the curser side to side on a large screen with one finger precision and less effort than it takes to say “effortlessly”!
My thanks to everyone who contributed to this outcome, including Mr. Li!
por
Great! I will give this a go.
Also, new silicon feet are on the menu.
por
Here's the needed battery: TIS 2217-2548 Lithium Ion Battery (AliExpress)
Magic Trackpad 2 Teardown
You can try, post Renault!!
Pontuação 3
2 comentários:
I just made this repair using the battery listed here. The battery took 25 days to reach me from the time I ordered. My old battery had swelled and pushed the back of the case open, so the backing was easy to remove.
por
I just replaced my swollen battery with this same one from AliExpress, and it works fine. But just as the teardown explains, getting the rear panel off the trackpad is a nightmare. I used a hair dryer to soften the glue a little, but I spent the whole time worrying that I was going to bend the panel beyond its breaking point. Fortunately, it all went well. The glue kept its stickiness, so that sealing the thing back up again was easy. I would definitely have preferred tiny screws for this!
por
I removed battery and taptic engine not work... I checked twice, if battery removed, taptic engine not working via cable without battery. All basic functional working properly just connect via usb cable.
Pontuação 2
5 comentários:
I experienced the same issue. The haptic component (Apple's Taptic Engine) no longer worked when I removed the swollen battery from my unit. It's not a big deal for me because I didn't find it that useful. But it is something to be aware of if you want to use the unit without a battery.
por
Have you tried adding a spacer to fill the space? Maybe a piece of cardboard with aluminum foil taped to both sides to mimics the capacitance of a battery (if it isn't detecting the force)? I'm thinking out loud here, but it would be worth trying some things like that to see if the missing functionality is an electrical issue or a mechanical one. Also, try a heavier-gauge third-party lightning cable and a higher-amperage power supply. When pulling power from your computer, the device probably caps itself at 500 mA, but the Taptic Engine may draw more than that in instantaneous power.
por
If you salvage the small circuit board from the battery and snap off the two contacts to the LiIon cell itself, and reconnect that back in the trackpad then the taptic engine will work again, without the need for the battery cell.
por
I did the battery removal a long time ago and have been looking for a way to get the taptic engine working again. I just came across the recent comments in this thread. Does anyone know if there's a way to purchase just that circuit board? I didn't think to try and cut it off to keep.
por
@Ho Yin Cheng, maybe using just an electrolytic capacitor instead of the battery board would make the taptic engine work again? Maybe it just needs very temporary high current to do the click and this current is supplied from a capacitor which happens to be on the board?
(I may eventually find out, my trackpad became hard to click in the middle because the bottom is bulging - eventually I want to remove the battery as I use it cable connected all the time anyway. For the moment I just glued four washers to the bottom corners and it clicks nicely again.)
por
Same issue here, just followed the link to the replacement battery on AliExpress, but there are no longer batteries there for the A1535 Magic Trackpad. Only the A1542, which is apparently a slightly newer model. Does anyone know if these latter batteries will work with the A1535?
Pontuação 0
1 comentário:
I did replace my A1535 Trackapad with AliExpress Battery A1542 and it fits.
por
Attempted to remove the battery but accidentally broke the connector, on the motherboard, of the ribbon cable that comes from the top glass part. Resoldered it but nothing works now, it just shows the trackpad is connected. It's over 😭😭
Pontuação 0
1 comentário:
I have no idea if schematics are available (probably not), but my next step would be to attempt to trace where each of the four pins is connected to. Once you have an idea, check for continuity between the pin and whatever you can access, such as a pin on another device, a test point, or a via. As a last resort you could carefully scrape off the solder mask and use that as your contact point.
Did it tear off any of the solder pads when it broke? If so you'll need to use a piece of wire to reconnect the signal.
por
Adicionar a sua resposta
Richard Nathhorst será eternamente grato(a).
Visualizações:
Últimas 24 horas: 15
Últimos 7 dias: 101
Últimos 30 dias: 380
Ao todo: 11,778
