Ir para o conteúdo principal
O LG Neon GT 365 é um celular de fácil acesso que possui tela tátil e teclado deslizante para mensagens.
How to replace the mic
when i make a call i can hear their sound but they don't hear mine
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Based on the teardown, it seems like most likely the microphone is soldered directly to the motherboard. (Though the teardown doesn't show a good image of the board.) This practice is very common on these kind of phones.
I would recommend cleaning out the microphone hole on the bottom of the phone.
Imagem
I see this a lot with my customers. We clean speakers, microphones, and charging ports all the time.
I would take a small pin and gently insert it but not too deep (most phones are designed in a way that if you insert something in the microphone hole it won't damage anything, though I am not sure on this phone) to break any dust free. Then blow it out with air. and see if that improves the microphone sound.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Alem Degife será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 269
