Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
612 Perguntas Visualizar todos
My MacBook Air won’t turn on
My Mac died after cleaning it and changing thermopaste. The LED on charger lights Green and then Orange. What should I do? Tried doing SMC and NVRAM reset but with no luck. The Orange indicator turns Green and then changes back to Orange.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
When you say you cleaned it, what method did you use to do this?
Even without knowing all the details the first thing I would try is to see if you can get it to power on without the trackpad plugged in. It connects to the board with a small ribbon cable, which often causes power on issues for this model.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Юра Купер será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 31
