Ir para o conteúdo principal
Ninth generation of iPad, released September 24, 2021, available in 64 or 256 GB models. Model Number A2602.
Can I use iPad 7/8th adhesive strips for 9th digitizer?
I just got an iPad 9th gen. digitizer to replace my broken one, though it didn't come with pre-applied adhesive.
I can't find anywhere the strips for the iPad 9, so I was wondering if I could just buy and use 8th or 7th gen adhesive strips
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
That’s what I would do. Hardware layout for these 3 models is extremely similar, and I have found other listings which indicate cross compatibility between them for digitizer adhesive.
If all else fails, you can custom cut adhesive tape to fit. It’s just a MUCH bigger hassle. But that’s what many people did in the “olden times” before precut adhesive became more widely available. I have used this tape for other repairs of the same sort with a pretty good success rate.
Imagem de Custom cut rolls of Tesa 61395 double-sided tape for repair.
Produto
Tesa 61395 Tape
$8.95
Esta resposta foi útil?
Pontuação 5
Adicionar a sua resposta
Andrea Fazio será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 575
