Ir para o conteúdo principal
HP Pavilion x360 15t-br000 Convertible PC
5 Perguntas Visualizar todos
moved hard drive from Pavilion 14 to this one
I took my hard drive out of my Pavilion 14 and put it into this new Pavilion laptop, when I broke the screen on the old one. It works, but it is extremely laggy, no matter what Wi-Fi I used it is still slow. What software is there that can help with the lag, and is there a reason the laptop isn’t running like it should?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@pugmaster04 do you have a make and model for the HDD? Have you reinstalled the OS (What OS are you using)?
por
Adicionar um comentário
1 resposta
Solução escolhida
@oldturkey03 I have no idea what model. And I solved the issue by going to the Task Manager, which showed my memory at 81% capacity. So I selected all items and ended their task. They all stopped running, moving the memory usage back to 51%. Now the laptop runs smoothly.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Landon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 69
