Ir para o conteúdo principal
The Beats Solo Pro is for the listener who's always on the move. Noise cancelling is surprisingly effective for a pair of on-ear headphones. Although the sound signature remains bass-heavy, as is emblematic of Beats, it rarely overpowers vocal reproduction.
Why is my solo pro just blinking white light non stop for hours?
It’s just blinking white light for over 24 hours now and it doesn’t connect or turn off even when I tried all the resetting techniques online it’s pretty much useless and sitting there now
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
3 respostas
Pergunta mais útil
Hi
This issue is usualy caused by the logic board or the battery
Here’s what to try!
Try leaving them so that the battery goes flat and then try charging them up
You could also try disconnecting the battery by following this guide(this usually works in most cases)https://m.youtube.com/watch?v=SBeHaqnw45...
If the above doesn’t work I would try replacing the battery which uses the same link above
If all these don’t work please let me know
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 2
1 comentário:
I just destroyed my headphones trying to unplug the battery 😭😭 thanks so much apple
por
Hello. Tried all your steps.
Finally changed the battery. And it start again blinking white do you know what I can do more
Pontuação 1
hey man i was having this issue with my beats for the last 3 months, the battery percentages was extremely low to the point where i would plug the beats in to charge and had the similar symptoms that you've experienced. I saw one person say deplete the battery and try to recharge it. And so i did, i keep the beats open / On and had the loudest sound pay until the beats die. I did that until every time I open the headset, it wouldn't connect to my phone. I knew at this point, it was completely dead. Since last night I had allowed the beats to charge after noticing it had reached 35% with the same charging symptoms. At this point, I am currently using the headphones as normal!
Pontuação 0
Adicionar a sua resposta
Albert Eintein será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 86
Ao todo: 13,186
