Stuck on High RPMs
I recently cleaned my 2008 Chevrolet Silverado 1500 4x4 throttle body and now it's stuck on high RPMs any solution to how I could fix this?
Esta é uma boa pergunta?
Its either a Vacuum Leak, Bad Fuse, or a Faulty Air Control Valve
I see the Air Control Valve being the culprit on older cars because of high carbon buildup over time, giving you an P0505 Error Code. Speaking of error codes, did you use a Scan tool on the truck? If so, could you post the results here?
Esta resposta foi útil?
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 136
