Is there any way to fix the ZIF Connector on an ipad 8?
The ZIF connector that connects my ipad's home button broke off. Is there anyway to repair it or possibly replace it.
Esta é uma boa pergunta?
If the entire connector was broken off the logic board, it can generally be replaced. But it will require soldering know how to do it. Pictures would help determine if any additional damage was sustained to the board when the connector broke off, since the solder pads which the connector sits on may have come off with the connector. Those can also be repaired if need be. It's just a repair which calls for a specific set of skills.
The connector itself might also be repairable, but it's hard to know without an accompanying visual.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 160
4 comentários
The whole connectors? Or just the little locking bar?
por Alisha C
Maurico Smith post some pictures of the damaged part etc. with your QUESTION. That way we can see what you see. Adicionar imagens a uma pergunta já existente
por oldturkey03
The whole connect is completely removed@flannelist
por Maurico Smith
I am unable to post a picture at the moment @oldturkey03
por Maurico Smith
