Ir para o conteúdo principal
Repair and disassembly information for the first-generation Apple Watch SE, announced September 18th, 2020.
20 Perguntas Visualizar todos
Digitizer touch glass from series 5 works on SE?
Hello, I have successfully separate the glass from the display I damage the touch in process so I had to take out the touch , the question is the digitiser from Apple Watch Series 5 works on SE?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi
Iv had a look at some replacement parts and from what I have seen it should work because most of the parts I looked at were compatible with both the SE and the series5
What I would do to be sure is use a replacement part that says it’s compatible with both just to be certain;-)
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 2
Yes, it works! i just swapped and SE screen to an S5 LTE and works.
Pontuação 0
Adicionar a sua resposta
Stelios K. será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 330
