Ir para o conteúdo principal
Laptop/tablet híbrido fabricado pela Microsoft. Lançado em novembro de 2017.
Water seeped into the magnetic charging port, and it wont charge. :(
I had my laptop (in a case), the charger, and a cup of water and some other stuff in my backpack. I dropped my backpack and the cup of water exploded and wet the bottom of the bag. I didn’t realise it was a huge issue cuz i kinda forgot my laptop was in there- it was wet for probably 2 hours and water seeped into the charging port and it wouldn’t charge! I turned it on its side with a paper towel underneath it for 10 mins so gravity can draw out the water. I then used a blow dryer (on the cool setting) to help dry the port, and it still wont charge! I can use the C-port but its extremely slow. Its been abt 36ish hours, is it a lost cause?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
You’ll have to open it up and clean the area with ipa and check for any signs of corrosion on the board. The liquid has possibly blown a fuse on the charging circuit so you’d need to test it with a multimeter. If your struggling take it to a decent computer shop.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Plz Help 😭 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 20
Ao todo: 2,317
