Will not power off or connect to Bluetooth
My Hk Auora will not power off. It also won't connect to Bluetooth. It's like it's stuck. I've tried to unplug and press power and Bluetooth simultaneously...no resolution. Help
Esta é uma boa pergunta?
Hi
Have you tried opening it up and unplugging the battery?
Doing this usually helps iron out any issue like the ones you are having
If you don’t want to open it up you could leave it on and wait for the battery’s to discharge/die
I would also try removing it from the device that it’s connected to and reconnect or try a different device altogether
Hopefully this helps
If this doesn’t help please let me know
Any questions please ask
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 428
