Why is my phone half screen only when it gets light
Esta é uma boa pergunta?
If your phone is cracked, chipped or broken then it's a obvious one if none of the problem is there then try the following.
Esta resposta foi útil?
After it was hitten on the middle part of the screen the bottom half of the screen only shows only white color when its on until i flash a beam of light In the sensor part
You’ve answered your question. Hitting the screen on the middle has damaged it. You need a new screen.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 57
