Ir para o conteúdo principal
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 Perguntas Visualizar todos
Diagnose why laptop won’t charge
I am not getting a green light on my MacSafe adapter and my computer will not power up. It thinks it is plugged in because when I hit the power button it displays the empty battery symbol with a lightening bolt, but no plug
I replaced my power supply and batteries a couple of years ago so I am suspicious the problem is somewhere else. Is there a way to determine whether the problem is in the MagSafe board or the logic board?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adicionar imagens a uma pergunta já existente
por
Adicionar um comentário
1 resposta
It could be a internal issue. Most probably liquid or moisture damage on the logic board. as it is quite old model, this is very common in macbooks. its better to get it diagnosed by a technician. i have repaired hundred of macbooks with this problem.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sara Shoemaker será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 25
