Ir para o conteúdo principal
The Early 2009 Mac Pro—also known as the Mac Pro 4,1—introduced Intel's Nehalem architecture to Apple's line of professional desktop computers in March 2009. The Mac Pro 5,1 used the same interior design but received further CPU updates in 2010 and 2012.
What washers to use?
Hi, I want to upgrade to a Xeon x5670,
I was told I need a spacer (2-3 mm maybe)
I can't find the washers.
Thanks! :-)
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi @beanman56
Here’s a US link for some 2.5mm washers
https://www.ebay.com/itm/112485217622?_u...
UK link
https://www.ebay.co.uk/itm/383536842495?...
I don’t know where you are in the world but these are the 2 most common place I know of
If you live out side of these place let me know and il find you some one from a different place
Hopefully this helps
Esta resposta foi útil?
Pontuação 2
30 comentários:
@hellomacos - Now i will upgrade to the Xeon x5670,
Thanks, Also do think this listing is good? https://www.ebay.com/itm/275378766660?ha...
por
@beanman56
Seems good
Did you consider the X5675?
They are also quite good on performance
I have them in my Mac Pro
por
@hellomacos - I thought the X5670 is about the same as the x5675,
Is this listing legit?
https://www.ebay.com/itm/354183915016?ha...
por
@beanman56
Seems to be legit
por
@beanman56
It’s really up to you if you want to save some money as the only real difference is the clockspeed
por
Exibir mais 25 comentários
Adicionar a sua resposta
Ben Capehart será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 282
