Ir para o conteúdo principal
Released by Samsung in March 2016. Model SM-G930, Versions: G930F (Global); G930FD (Global; Southeast Asia); G930W8 (Canada).
How to fix "Camera Failed "
How to resolve this issue
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I believe verizon was involved to shut down the phone so that you have to purchase another phone as the only option ended up being ! That is what took place with my phone as all the options totally disabled the phone from working at all !
por
Adicionar um comentário
1 resposta
Pergunta mais útil
I don't personally have any information for you, but I ran across an article on nextpit.com that claims to know how to fix the Camera Failed issue. They say it's strictly a software issue, that there's nothing wrong with the phone itself.
  1. Restart the phone.
  2. If that doesn't work, go to the applications manager under settings and clear the data and cache for the camera app.
  3. Otherwise, put the phone in recovery mode and wipe the cache partition.
  4. If it's still not fixed, go into the display settings and turn off Smart Stay. That may fix it in the short term, but according to Samsung the long term fix is to update your phone's software, as it's apparently a known issue that's been fixed in a later revision.
You can get details on each step at the original article here.
How to fix 'camera failed' on Samsung Galaxy smartphones
Hope this helps!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Gregory Lazar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 918
