Ford Focus horn failure. Please Help!
I have a Ford Focus Estate, I got cut up at a junction and was unable to show my displeasure in the usual way as the horn stopped working. Any help would be great.
Esta é uma boa pergunta?
Fuse brown, solenoid failed. Check the manual for which number fuse it is and check it first. Also check the wires that go to the horn as they can corrode and break off.
Esta resposta foi útil?
Unfortunately it wasn't that simple, tried all of that and still no noise.
Faulty horn? Test it then if working maybe a faulty horn switch. Put a multimeter on the horn wires and have someone push the horn button. If all else fails then possibly a break in the wire somewhere.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 381
