Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
Is it possible to separate the LCD?
Hello, I have 2 iPhone 4S's and one of them has a cracked glass but a good LCD and the other one has a non cracked glass but has a cracked LCD on the inside, when I was checking the tutorials I saw that I had to remove the glass panel with it which i dont want to. Help?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
You can separate and reattach the glass with appropriate tools, which probably cost a truckload of functional iPhone 4s now.
Esta resposta foi útil?
Pontuação 0
Short answer: No. The display is laminated to the glass; they're effectively one piece. Separating them without further damage requires specialized equipment and/or a whole lotta luck, and even if you do manage to separate them re-laminating the pieces together (to make an actual functional piece) still requires specialized equipment and materials.
Pontuação 0
Adicionar a sua resposta
Bwar Bahzad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 85
