Ir para o conteúdo principal
The Sure Shot Z115 Caption is a 35mm film-using camera made by Canon. It features an aluminum cover, a 38-115mm f/3.6-8.5 zoom lens, a flash,and a variety of picture-taking modes.
My Canon Z115 display is dim
I put my Canon Sure Shot Z115 in my carry on bag and when I put it on the plane, something else in my bag must have turned the dial. The camera was on for the whole flight and the display is hardly visible now. I replaced the batteries and while everything else still functions, the display is too dim for me to even see what settings it’s on. Is this something that can be repaired/ replaced?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Check the settings to see if there is a brightness setting and try that. If that doesn't work, you may need to replace the display. Hope this helps!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Tiffany será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 4
Últimos 30 dias: 5
Ao todo: 224
