Ir para o conteúdo principal
Tudo que você precisa para reparar por conta própria o seu iPhone! A iFixit tem guias de reparo gratuitos e informações de desmontagem para cada um dos modelos iPhone, assim como as melhores peças de reposição e ferramentas da galáxia!
36476 Perguntas Visualizar todos
Pergunta encerrada
How do I reconnect the motherboard ribbon cables?
I have watched and read many descriptions of how to disassemble a 1st gen iphone, but have found none that show me how to reassemble one.
I am having great difficulty reconnecting the ribbon cables beneath the motherboard. Is there a special tool for this? Thanks much.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
With your finger ? If you disconnected it by prying it with a spudger, just put it back by pressing the connector to its socket, but verify is well lined up.
Esta resposta foi útil?
Pontuação 1
4 comentários:
M specific issue is with the digitizer ribbon once the other three are already connected. I can't get my finger in there.
por
My fingers are unable to connect any of the Logic Board Connectors except for the Back Case Flex Ribbon. The rest I lay the Logic Board carefully in its position, then I slightlhy lift the board up and using a thin probe push them into place basically upside down, sometimes even just pushing the board back down on the connector while the probe guides everything. Its a bit of trial and error and carefully inspecting underneath, because you don't want to leave one undone that you connected earlier.
por
I see, I've never had an iPhone 1G in hands, but I read the guide more carefully. What I'll do after replacing the one step 25 is putting the others back using the spudger as a lift, it must be coarse but I don't see any other way to do it. Once again I can't help much as I've never done it with an iPhone 1G
por
it's a very tricky setup but the only other tool to use here is a pair of tweezers or forceps. I nearly pulled my hair out trying to do this but managed with just fingers..
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 3,378
