Ir para o conteúdo principal
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
124 Perguntas Visualizar todos
adhesive on the edge where the display cables are running
Hello,
during the opening of my Apple Watch 4 serie, I broke the adhesive on the edge where the display cables are running, cutting the two connections towards the two corners on the bottom of the case.
Question: which is the technical function of this adhesive? is it strictly necessary? Is it available as spare part?
Thank you
Regards,
Giancarlo
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi
The screen connector adhesive you are on about that really only holds down some black tape to cover the connectors so I wouldn’t worry about that:-)
Hopefully this answers your question
If you need any help please ask
Esta resposta foi útil?
Pontuação 1
8 comentários:
Hi,
thank you for the answer. I know the force touch. My question is regarding the adhesive very thin that is behind the display that keeps the three flat cables of the display glued together.
por
@gianko
That adhesive doesn’t serve much of a purpose other than covering up the connectors:-)
por
@hellomacos good news, thank you very much! have a nice day! :-)
por
@gianko
Have a nice day too!
por
@hellomacos - Please becareful as some of your comments of late don't solve the underlying problem/s or deal with the ramification of incomplete information.
I would stick with areas I know intimately from experience, maybe even looking through older answers to see if the question was asked before and then pointing to that question and answer. I always try to supply data to back up what I've offered that helps people as well.
por
Exibir mais 3 comentários
@gianko - The black copper tape is an EMI shield and you do need to be careful as you don't want it shorting out things. How about posting a picture or two so we can see things Adicionar imagens a uma pergunta já existente
Pontuação 0
Adicionar a sua resposta
Giancarlo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 81
