Ir para o conteúdo principal
The second generation 11" iPad Pro was released in March 2020 with the model numbers A2228, A2068, A2230, and A2231.
20 Perguntas Visualizar todos
Why does my ipad keep rebooting nonstop
it keeps rebooting and I can not turn it off and after it dies I turn it on and it does the same thing over and over again.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Is you power button on the device stuck? This is one potential cause of the boot loop you are experiencing. Another is software corruption. You can try forcing it into restore or DFU mode to reset.
Esta resposta foi útil?
Pontuação 0
Usually this failure is due to a broken FrontScreen /FaceID) assembly. If you disconnect it, the iPad will start fine, but you will not regain FaceID functionality (or you need to purchase a new FaceID cable and replace the sensor from the original cable).
Pontuação 0
Adicionar a sua resposta
daniel bates será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 94
