Ir para o conteúdo principal
A simple point-and-shoot digital camera with LCD by Canon.
I put in new batteries and camera is still showing low batteries
Esta é uma boa pergunta?
Pontuação 3
2 comentários
Hiii, did you solve this problem? im currently on the same issue
por
@antoniaarr19349 What I've found is just to wait a little bit until the camera decides to work.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi reomared,
What kind of batteries did you put in? Standard AA batteries from the store, or quality high capacity (>2500mAh) rechargeable batteries that was fully charged?
For digital cameras that use AA batteries, good quality >2500mAh rechargeable batteries are recommended.
Those non-rechargeble AAs you buy in the supermarket are sometimes fairly old when bought, and if they do work it's nowhere near the ability of good rechargeable ones.
I used to use 2800mAh Energizer ones in my battery grip for my Canon dSLR (it used 6 of them with an adapter) and I had hundreds of shots (with flash) before needing to recharge.
Esta resposta foi útil?
Pontuação 2
2 comentários:
I understand that rechargeable batteries would be better but I have always used Rayovac fusion 12 year power guarantee in the past. Why now all of a sudden they don't work?
por
@reomared This is just speculation on my part, but the batteries you put in «could» be old stock. Batteries should have a date of manufacture on them, depending on where they’re produced and the governing law in your country.
Even though manufacturers say a battery is good for 10 years «on the shelf», that’s unfortunately often not the case.
por
Adicionar a sua resposta
reomared será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 1,905
