Ir para o conteúdo principal
Repair guides and support for M1 24" iMacs by Apple, introduced in April 2021. Model: A2438.
18 Perguntas Visualizar todos
Is It Possible to connect External Video Card? And which one? Thank yo
I have iMac M1 24" with 16GB Ram and 1Tb SSD, is it possible to connect external Video Card? I saw is was possible with intel iMac, but what about M1? Please advise.
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
While you can connect via USB-C an external GPU unit (eGPU) in the Intel systems, I'm not sure if you can with the M1 or M2 systems. There is also the issue of which display you are driving. Driving your internal display steals away needed bandwidth for the eGPU, instead you'll want to connect an external display.
Reference: Use an external graphics processor with your Mac
I do wonder if an eGPU is that useful with the 24" iMac, part of the issue is within the M1 SoC as its has some limitations with its TB ports. You'll need to speak with the different vendors listed in the guide I posted above.
Esta resposta foi útil?
Pontuação 1
There is no list of compatible GPUs, but it is possible. These Macs have Thunderbolt 3 connections, which you can plug an eGPU into.
Pontuação 1
Adicionar a sua resposta
Yarik Sabitov será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 44
