My TCM-919 player is not spinning
I put on the batteries already but when I press play or record nothing is moving but it make noises but no music from the tape and I can see the tape is not moving
Esta é uma boa pergunta?
There is only one way: use this guide and open the device. Switch it on. Have a look to the gears, perhaps you can see a broken rubber belt?
Esta resposta foi útil?
How can I know if the rubber is broken or not?
@iitoobb Step 5 picture 3 of the above guide shows the rubber belt from the motor to the spindle. That is the belt that will have to be present.
Thanks , I’ll try to find a new rubber belt because mine looks more loose
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 127
