Ir para o conteúdo principal
The RIDGID R7111 VSR heavy-duty drill has an 8-amp motor, die-cast all-metal gearbox, and a 1/2 inch keyed chuck for maximum durability and high power. This device is frequently used for at-home projects or for large constructions jobs due to its versatility and long-term use.
1 Perguntas Visualizar todos
Rigiid R5010 Corded Hammer Drill -- CHUCK STUCK
Lent drill (Rigid R5010 corded hammer drill to neighbor -- big mistake - returned it and did not tell me that he had to force the bit out.. now chuck is jammed) . Would appreciate advise on how to unstick chuck or process to replace it and recommendations for a KEYED type check replacement...
Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Two things.
  1. This answer may help you here
  2. Your manual tells how to remove the chuck
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
NIck-C será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 14
Duração total: 198
