Ir para o conteúdo principal
Repair guides and disassembly information for the 16-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2485.
50 Perguntas Visualizar todos
Blackscreen on MacBook Pro M1 Max 16‘‘ but external display works
Hi,
the title says it all. I saw a glitchy pixel line at the top flickering a few seconds before the screen was just black. All i have as a second screen is a laggy tv. I obviously restarted already and installed the latest macOS update. I use tools like BetterTouchTool, Alfred and Bartender, if that may cause an issue maybe (?)
It happened after I transported it in a backpack. But this can only be a coincidence, because the laptop is well protected in a special compartmant and i have nothing inside the pack that could pressure damage the display or something. The case itself also doesnt show any signs of cracks, scratches, dents, bents or anything.
The battery is also fully charged and I have never used any third party method to charge it.
During the macOS update the tv got no signal but you could see a very dark and very blurry image of the apple and the progress bar.
Using my iPad in sidecar mode froze the image on the ipad after 1 or 2 minutes. The tv signal was solid though as long as i didnt restart or pressed the power button or something.
In the sea of outdated articles I tried a few things but every restart or long press of the power button results in no signal on the tv. so its very hard and frustrating to not see anything at all.
i dont know what long pressing the power (touch id) button does, though… as i cant seeee it :D
Ive read a lot that this is more often a software issue than a hardware issue and would like to avoid sending it in.
Since I’ve had very good experiences in this forum already, I hope you guys will rescue me once again :(
Thanks!
Esta pergunta é pertinente?
Pontuação 1
Adicionar um comentário
4 respostas
Solução escolhida
Sadly, this does sound like a hardware level issue. I'm a bit lost in some of your testing are you able to see a clean image either via an external monitor or remotely to the system? If either work then you have a internal display failure.
Esta resposta foi útil?
Pontuação 1
20 comentários:
I now fail to get an image on the tv aswell. I dont even know if the machine is really booted or not. i cant see anything and cant find out how to restart it by key combinations. Shouldnt I at some point here the famous bootup sound when the apple logo shows?
por
I can see that the tv gets a signal, but its also black. When I unplug the hdmi cable from the laptop, the tv immediately says NO SIGNAL and starts the shutdown timer.
por
@katerlouis - Ouch! Then things are even worse!
Yes, you should get the startup bong (unless you turned it off) as this point its clearly hardware. Time to give Apple a call to arrange a service call or pickup if you're too far from an Apple Store.
If you haven't yet, after its repaired I would recommend signing up for AppleCare+ so you have a bit of a cushion as the repair costs of these newer systems is quite high!
por
Could it be that there is just a connector lose? I remember a viral video a few years ago where a guy fixed a very similar issue in just a few minutes where Apple wanted to replace a bunch of stuff for high cost.
por
When I rapidly press the power button a voice assistance starts to read stuff very fast :D - so the machine seems to be on.
por
Mostrar mais 15 comentários
Has this issue of yours been resolved? I bought a MacBook Pro 14" 4 months ago and this black screen issue began. Have given it to Apple, they reinstalled the latest OS and it worked for 2 weeks, but the problem is back. When connected to an external monitor, I can use the Mac (that is how I'm typing this reply), but on its own it's useless. Have tried everything for the last 2 weeks. Does this seem like a hardware issue? Because when Apple kept the system and ran a check for 24 hours, it showed no hardware issue. I'm lost.
Pontuação 0
1 dos comentários:
It has been resolved, yeah– A certified Apple store here in Germany also installed a new firmware on some kind of chip (?) which shouldve required a reinstall of macOS, but weirdly didnt... although they were sure this wouldnt solve the problem, they still had to stick to that protocol, where a straight up screen replacement wouldn't have required a macOS clean install. Anyhow: They changed the screen and I haven't had issues since then.
Unfortunately I have no tip for you on this one :( – Mine was constantly black with no life whatsoever. Only backlight was visible when Apple logo for instance was on black background during startup. I suggest you open your own thread here. Very helpful and nice guys here! Glad to have this resource and appreciate any help.
por
Press and hold the power button for about 10 seconds. Press and release the power button, then immediately press and hold Command -R until you see an Apple logo or other image.
Regards,
Peter
Pontuação 0
Sorry this did not work. My power button has the touch Id. The moment I press the power button is powered up, I heard the boot up sound, but screen remains black.. Once I connect to an external monitor, I see my login screen waiting for me to enter my password.
Pontuação 0
Adicionar a sua resposta
Kater Louis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 39
Últimos 30 dias: 138
Duração total: 927
