Ir para o conteúdo principal
The LG V60 ThinQ 5G, commonly referred to as the LG V60, is an Android phablet manufactured by LG Electronics as part of the LG V series. It was announced in February 2020 and is the successor to the LG V50 ThinQ. On April 5, 2021 LG announced it will be shutting down its mobile phone division and ceasing production of all remaining devices. LG noted the phone will be available until existing inventory runs out.
Will the fingerprint unlock function fail if I replace the motherboard
Will the fingerprint unlock function fail if I replace the motherboard ?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
My guess is a motherboard replacement removes all data; phone numbers, song lists, files, and fingerprint data. Basically restoring a phone back to factory settings with a new motherboard. If all data was saved up to a cloud or can be transferred to the manufacturer's datasite for retrieval to download at anytime then your fingerprint data is saved otherwise you'd have start the procedure to scan for fingerprint data.
por
Adicionar um comentário
2 respostas
no it will not work.
Esta resposta foi útil?
Pontuação 0
Swapped new board for V60 and fingerprinter work fine.
Pontuação 0
Adicionar a sua resposta
TDEZ será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 9
Ao todo: 165
