Ir para o conteúdo principal
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Perguntas Visualizar todos
iFixit Battery Micro Controllers out again?
Been through this once before with my horribly unreliable Retina MacBook Pro. Went to turn it on and it would not. Plugged it in, took 5 minutes to boot, no battery detected. Contacted iFixit customer support and haven't heard back yet. Assuming they have the day off today. What do y'all think, same issue? Micro Controllers out?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Did you try a SMC reset? If you did with no change then its the controller chip again. Sounds like a bad batch issue ;-{
Esta resposta foi útil?
Pontuação 1
2 comentários:
Yeah, reset the SMC and the PRAM and there was no change.
por
@Dominic Bono - Sorry to hear you got a second bad battery. Don't forget to accept the answer - Thanks!
por
Adicionar a sua resposta
Dominic Bono será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 36
