Ir para o conteúdo principal
The Oculus Rift S is a PCVR headset with 6DOF tracking using cameras located on the headset itself.
The display cord for the rifts
My display cord is disconnecting and reconnecting it happens every 1-5 minutes and goes dark for about 30 seconds every time I’m pretty sure it is my display cable every time it disconnects it says it is disconnected on the oculus app.
Esta é uma boa pergunta?
Pontuação 3
1 comentário:
Its &&^&@@. All oculus cables are meant to fail eventually starting with bullshit that happens like this and will get worse overtime until eventually.. NADA!!
por
Adicionar um comentário
1 resposta
Best advice I can give is to remove the part of the headset your face rests against (it just pulls out and snaps back in), and removing the cable and putting it back in. I have the same problem and I'm trying this solution now.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Noah será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 1,732
