Ir para o conteúdo principal
Released in October of 2020, the Dell XPS 13 9310 is physically very similar to previous models but has optional upgrades for graphics and the processor. This device does not cover the 2-in-1 model.
2 Perguntas Visualizar todos
Headphone jack broken- is this soldered onto the system board?
Dell XPS 13 9310. Headphone output is broken- can only put headphone jack part way. Can't see a foreign object in there.
Is the headphone port soldered onto the system board?
If I replace the system board, is the CPU on the system board, too? (Ie would I need to transfer the CPU from old board to new?)
Thanks.
I found out the solution: the jack itself is on the case. Not the circuit board. No idea how to replace it though.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It's on the bottom case, not the circuit board.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Eric Rickin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 324
