Start up screen is green
I went to turn my Wii on and the entire screen is green.
I pressed the Wii remote it does the indication that I press the A button and the usual sounds it makes when you're on the main screen are there but everything is green.
What is the best way to tackle this problem ?
Esta é uma boa pergunta?
4 comentários
How is the Wii plugged into the TV? Composite, component, or HDMI?
por Andrew S
@andrewsawesome The Wii doesn't have an HDMI port.
por guardian10
@guardian10 There is an adapter called Wii2HDMI that some people use.
por Andrew S
I use the standard AV cable that comes with the Wii so basically I use the one that has the red, yellow, and white color coded cables
por Adam
