Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
NTC error after FaceID Repair
Hello,
I had Face ID failure on my IPhone X phone. So I decided to fix it. I did all the steps in full and pass the module to a new flex. When doing the test with my I2C tester it passes all the tests (leds turn on...) but the NTC fails. I don't know if it's the fault of the new flex I bought or what. Attached photo of the tester and the module.
Thank you very much.
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
my too
Do you have any solution?
por
@vanthea - Sorry there is no solution other than letting Apple repair it as they can update the security credentials of the part.
por
Adicionar um comentário
1 resposta
Sorry FaceID and NFC security elements are part of the circuit so while you replaced the part and your tester is telling you the part is working physically, its not going to allow the replacement circuit to work as the security keys are not correct (as they are new). Only Apple has the tool to reprogram the phone for the new key.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Im not replacing it. Im doing a dot projector repair.
por
@pwnorz - See if clearing the FaceID and reloading a fresh image fixes it. The stored image maybe off. Otherwise there maybe security linkage between that is messing you up.
por
Adicionar a sua resposta
Vladimir será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 27
Ao todo: 1,918
