MacBook sleeps when unplugged. Battery not recognized by coconut.
I purchased a battery from iFixit in March 2022 for my Macbook Air 2017 i5.
I installed it, and at first it was working great. Then about 1 month ago, the system stopped recognizing the battery. When I unplug the power adapter, the computer goes into some kind of sleep or hibernate mode.
CoconutBattery says it doesn't even see any battery. See https://imgur.com/a/MhSTYXe
Oddly enough, I think the battery is actually charging, and sort of being used. When I plug in the power adapter, it shows green for a moment then goes steady on orange. And when I unplug the magsafe power adapter, I can hear the fan continue to run as it shuts down to sleep/hibernate mode. And of course, when I plug it back in and press the power button, it takes a few moments to revive back to the original run state.
Another strange symptom, is that the system runs VERY slow. I've read elsewhere that a problem with a battery might cause a slower system.
I've tried the oft-recommended software PRAM and SMC reset through shut-down and using various key-presses. I've tried a hardware SMC reset by removing the battery and holding the power button for over 20 seconds. None of those worked. Of course, that also involved re-seating the battery. I've inspected the top of the logic board (without removing it) with a magnifier, no apparent discoloration or charring. No odd smell on the logic board either.
I've opened up a ticket with iFixit.com, but I figured I'd post here as well.
Esta é uma boa pergunta?
3 comentários
Sounds more like a logic board than a battery issue. Charging IC and logic battery circuitry are on the top side of the board which you can't see unless you take it off the Mac.
por arbaman
@arbaman Thanks. Oddly enough, the issue was the battery. Answer has been posted fyi. Thanks for helping me!
por David L Stein
@coolhandlouis Yeah, i read your updates and the further attempt to run on the first battery you received. Well done, despite the weird glitches you experienced, it's reasonable to call the battery as culprit. Strange or hard to explain things happen from time to time.
Thanks for taking the time to report back!
por arbaman
