Ir para o conteúdo principal
The Oculus Rift S is a PCVR headset with 6DOF tracking using cameras located on the headset itself.
Can I fix the tracking on the headset
my headset keeps loosing the tracking no matter how much light or dim or no light there is. It should work and it did in the past but not anymore, it holds the trackign for a short time then says "lost tracking" and it can't get the tracking back. Is there a way to fix this? so it can keep holding the tracking and not loose it a few min after
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Did a quick search and found 3+ pages similar to this one with possible solutions to your problem, if none work, give a holler.
Esta resposta foi útil?
Pontuação 2
unfortuneltuy the tracking can get better but never as good as it was
Pontuação 0
Adicionar a sua resposta
mikkel hansen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 28
Ao todo: 1,601
