Spacebar intermittently works only in the middle only with firm press
Suddenly yesterday my spacebar stopped working as it used to. For it to work I have to really press it hard, which still not always makes it respond. The problem seems to be in the key's plastic cover rather than keyboard itself, because after removing plastic cover and cleaning it and space under it, spacebar seems to respond perfectly with just the rubber dome.
How do I fix the spacebar key?
Upd: Under a little investigation I've found out that the problem is in the loose dome which keeps moving away from the sensitive area during printing. What's the proper way of fixing it in place?
Esta é uma boa pergunta?
