Ir para o conteúdo principal
Released on September 18th, 2020, the Samsung Galaxy Tab S7+ 5G (SM-T976B) is the larger, more powerful version of the Tab S7. It features a 12.4-inch Super AMOLED display, a Qualcomm Snapdragon 865 processor, and 5G capabilities.
5 Perguntas Visualizar todos
Not charging after update
After updating the tablet to android 12, everytime I plug in a charger, a notification pops up saying "USB connector connected/disconnected" it keeps popping up every second and the device won't charge. I am using an original Samsung Charger
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
You can try a soft reboot (no data loss) press power and volume down buttonus simultaneously hold them until you see the tablet restart. Ignore the screen until you see the startup screen, release the buttons also check in settings and see if it is still showing available update.
por
Mine just started having this same issue but this was both before and after the android 12 update. Updating didn't break it or fix it, for me at least, it appears.
For me, if I flip my new Anker cable around "upside down" it will work. If I put it Anker logo up, it disconnects/reconnects 3 times a second if connected to my Anker power bank.
My Anker super fast charger and it's different cable are the same way, but opposite cable direction.
Moral of the story, all of our cables decided to break at the same time, obviously.
No, it appears Samsung actually just broke all of our tablets at once. Thank you, Samsung. I don't think yours is physically damaged.
por
Adicionar um comentário
1 resposta
I replaced now the USB charge unit and the battery. Both replacements don't solve the problem. For this case the temperatur sensor or the measurement device is placed on the mainboard. I hope this info helps other people on this webside.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Any fix ?
Mine is having same problem
por
Adicionar a sua resposta
Roel Docto será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 960
