Ir para o conteúdo principal
{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
276 Perguntas Visualizar todos
Part of the LCD have bad pixels
Hi :-)
I have got a MacBook Pro 2017 13" mid 2017 model, since yesterday a stroke seems to be bad on the LCD screen. It seems to be more visible when the background is turning dark, I refer to the pictures underneath. (I closed the cookies pop-up in the picture)
When I close or open the MacBook in every position nothing changes.
I have reset the PRAM a few times, but does not help.
I have tried an external monitor, the screen is fine on the external.
I hope it will be a easy diagnose and fix.
Thank you.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It could be a hardware issue since it is not showing up on the external monitor, it has nothing to do with the graphics. Possibly something has damaged the screen and has caused it to do this. I don't know much about software, so I don't know if something there could be wrong.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Yes, the displays T-CON board has a problem. Here's the needed part MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and the guide to put it in MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement
por
Thanks both. I'm not gonna fix it. Fingers crossed it will not be worse.
por
Adicionar a sua resposta
Peet será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 66
