Ir para o conteúdo principal
The Samsung Galaxy S9 is identified by its model number: SM-G960XU. It is the ninth generation of Samsung's Galaxy Series that was released in March 2018. Available in Lilac Purple, Midnight Black, and Coral Blue.
130 Perguntas Visualizar todos
Why would the GPS not be working after a screen/battery replacement?
Hi everyone. This is my first post. I figured I'd come on here and see if anyone knew more than me about the S9.
I fixed my girlfriend's Galaxy S9 with parts from InjuredGadjets.com. I got a new display+frame, and a new battery since hers was shot, barely lasting an hour on a full charge. Ever since I fixed it a couple months ago, her Google Maps is unable to navigate due to a lack of a GPS signal. The marker/arrow that indicates us/our vehicle turns gray and the app says "Searching for GPS". Eventually Maps will just give up and verbalize "GPS signal lost". We've tried wiping the cache, both from the partition and the app itself, force stopping Maps, starting the S9 in safe mode, and I even tore the phone down again and made sure ribbon cables were seated and re-seated them. Still nothing.
Am I missing something here? Maybe I missed a ribbon cable somewhere? Do the antenna cables have anything to do with the GPS? Her data signal is fine, and she can still make calls.
I also read that sometimes 3rd party batteries can cause this issue. Is that true? Maybe that's the case. The battery is an XCap or whatever.
I really appreciate any guidance on this. The initial repair of the phone was easy, but this issue definitely should get fixed. Last week there was an accident on the road and she struggled to get home from work because she couldn't use Google Maps. Usually I'm the one who drives us around and navigates using my S10e with Android Auto, but this should still definitely get fixed in case of an emergency.
Thank you for your help!
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Maybe a silly question, but we have to start somewhere. Are location services turned on?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
The antennas are on the frame and the plastic inner shield, there may be multiple S9 models with different antenna designs to fit different carriers. Check if you have bought the correct model and the seller actually shipped the correct one to you.
Also if possible, check every contact pads and spring contacts on the frame and the board, especially on the upper side, they are the actual GPS antenna connections.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Rick Yoder será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 47
Duração total: 428
