Ir para o conteúdo principal
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
137 Perguntas Visualizar todos
My iPad 6th Gen is turning off randomly
Hi i have a Wifi iPad 6th Gen tablet, and i got it from used. Now that is my problem, i was using this tablet heavy or low power mode, but randomly turns off without any messages, just boom black screen, after the tablet wait 10 s and can be turned on. this is so random that happened one after 2 days and 2 full racharge and discharge, but happened 2 shut off after 1 hour of use. The tablet past is got resoldered the main CPU and the charge ic chip, because they guessed that not worked. but the issue is still there. I have not found a single short on the board neither the cpu, or powerlines. I tried power on with the minimum components as possible (power button, lcd and battery). I checked the battery health and says 540 cycles in it, and the health is ~90%. I am clueless, every part is the original that came from the factory, i stresstested the cpu maybe the heat causing it, but no. Please help, i am clueless whats causing this issue if someone knew what the issue i will be happy! Thanks for the help community! <3
UDPATE: i have placed thermal conductive pads over the Processor and the PMIC chip, and now the random turn offs are rare or completely gone now, i have using this tablet over a week like now and not turned off by itself, but its really wierd if you are using this long enough the rotation detection is off and you can resolve just by turning it off and on. And that is the only issue now, i have faced so far.
Esta pergunta é pertinente?
Pontuação 1
Adicionar um comentário
1 Resposta
"The tablet past is got resoldered the main CPU" - this raises a red flag, as far as I know, resolder CPU is no easy task. My guess is whoever worked on this didn't do a proper job, you can tinker with CPU as a last resort, but I doubt that's going to solve the random shutdown issue.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Hi! Thanks for the help, maybe this motherboard is gone and it will get worse…
por
Maybe this can give a little information for the issue?
"panicString" : "panic(cpu 1 caller 0xfffffff018ea9dec): \"AppleTriStar2: could not find system ID: bad IPC message ID bf 1 84 f0 24 0\" @IOAccessoryManagerAID.cpp:44\nDebugger message: panic\nMemory ID: 0xff\nOS release type: Not set yet\nOS version: Not set yet\nKernel version: Darwin Kernel Version 21.5.0: Thu Apr 21 21:51:23 PDT 2022; root:xnu-8020.122.1~1\/RELEASE_ARM64_T8010\nKernelCache UUID:
por
Adicionar a sua resposta
Szabi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 199
