Ir para o conteúdo principal
Repair documentation for the 3rd generation 11" iPad Pro (model numbers A2377, A2459, A2301, and A2460).
iPad Pro 11" 2021 Mic not working on FaceTime calls
So i replaced the Screen assembly on an iPad Pro 11" 2021 and the mic is not working for FaceTime calls, but it works for voice recorder. Would anyone know which mic is for FaceTime calls? TIA
Update (05/26/2022)
*UPDATE* 05/26/2022
Mic work on this Apps:
- Voice Memos
- Frontal Camera videos
- Rear Camera videos
- Siri con take voice commands
Mic doesn't work on this Apps:
- Face Time Audio
- Face Time Videocalls
- FaceBook Messenger video calls
Esta é uma boa pergunta?
Pontuação 4
5 comentários
I have exactly the same problem on exactly the same iPad model. It worked well from June 2021 when purchased. As of around Nov 1, 2022, Mic does NOT work on FaceTime, Zoom or Skype. Mic is NOT muted. For Facetime people hear only "white" noise that is muted when I mute mic. I know Mic works as I used both Record Apps and verified both Rear and Front facing mics work with the Camera Video. The issue relates to Mic getting OUT of the iPad.
I have tried everything including connecting via my iPhone 12 Pro hotspot ... to eliminate a block with my WiFi. All works fine with the iPhone.. I have never dropped or abused the iPad. I don't believe there is a hardware problem as the above person as Josh Friesen suggested.
My best guess is an IOS update such as a late IOS15.#. No change when yesterday I took ISO 16.1.1
ANY IDEAS WOULD BE APPRECIATED.
por
I believe this problem began with iPadIOS 15.6.
Apple - time for you run a simple test with 16.1.1 that still exhibits voice not heard thru mic (only white noise that changes based on the relatively new feature (std, spatial, wide) for FaceTime and NG in ANY APP THAT COMMUNICATES OUT OF iPad.
I believe one of your IOS updates slipped thru your in-house and Beta QA network. This is NOT A H/W issue
Report YOUR result on an iPad Pro, probably any generation to the community. Mine is a 2021 11” Gen 3.
Kindly say a bit more about updates when releasing an update. Please state this issue was corrected when you’ve done so In a future, soon please IOS update.
Please restore my $850 purchase to full functionality as it was up to IOS 15.4.
por
Have you successfully solved this problem? I am officially up against a wall with this issue. Been living with it for 2 years and now need a solution. Can’t do a crucial video 2FA because mic is not working for the app. Thank you for your reply.
por
I am so frustrated because I was recently required to do a 2FA using sumsub an identity verification app using video and voice. Of course my mic doesn’t work for it so I am now locked out of my crypto account and the exchange is not budging on this requirement. They of course don’t believe this is a real issue. I remember the day my FaceTime and zoom stopped working. It was the morning after an update in the 15.4.x era. A total bummer
por
I am also facing the same issue I never opened it neither dropped it or something…. Still I am facing the same issue…. Talked to Apple support and their senior advisors too on call but they told me to bring my iPad to them….why can’t they just simply divert other mikes to work if one fails so that this issue doesn’t exist in the first place
por
Adicionar um comentário
5 respostas
Solução escolhida
What solved my problem, was swapping the mic flex inside the iPad. Is a 2 mic y-shaped flex. Hope this helps.
Esta resposta foi útil?
Pontuação 0
2 comentários:
I’m happy that you managed to fix your iPad. As someone who repairs devices for fun, I know how frustrating these kinds of problems can be. Best of luck!
por
Could please forward from where you purchased that flex cable
por
I’d say that you probably damaged the front screen microphone flex cable when you removed the screen. There are 5 microphones on our model of iPad Pro. 3 microphones on the top of the iPad are very close together possibly resulting in inconclusive test results.
I believe that the small mic hole at the top of the screen is used for FaceTime and Facebook messenger calls.
I hope this helps, Josh
Pontuação 0
2 comentários:
Thanks for responding, that flex was swapped and microphone on facetime calls still won't work. I removed the top microphones, that flex that is on top of the iPad and still wont work. But voice recording is working,
por
Thanks for the extra information,
It could be one of apple’s sneaky ways to prohibit third party repair. They might be serializing the microphone? This is a strange issue and I honestly doubt that it was any mistake on your end.
por
Completing the list regarding this iPad Pro 11” bug still unresolved!
- Voice Memos
- Face Time Audio
- Skype app
Pontuação 0
5 comentários:
Same list of apps for me. Add ANY third party vid conference apps to the NOT WORKING list. Zoom, Webex, GoTo, etc.
por
Also, I brought it to the Apple Store. Since its out of warranty and I don't have AppleCare, they wouldn't fix. They only said I could swap it out with a certified used like model for $800. Passed on that since everything works with headphones.
por
Is that bug sorted ? Same issue is appearing for me as well..
por
Same here !! I have an appointment at Apple Store this coming Saturday. Tried everything on my end .microphone works fine in Facebook messenger when sending audio recording but not when doing live video chat. Tried other programs as well that do video chat and nobody can hear me. Recording videos there is audio as normal though .
por
What was the result of the appointment
por
Did anyone get a solution for this problem?
Pontuação 0
Same exact issue here. Anybody get a resolution on this?
Pontuação 0
1 comentário:
As Robert mentioned a while back, it seems that the Y-Shaped microphone flex cable at the top of the frame near the front camera was the culprit. It can be frustrating when these microphones go out because there is no easy way to test which microphones do what functions. This is a complex issue and I’m not sure if it is the same between the few cases mentioned in this thread or if the issue can be linked to a previous repair. I hope that helps!
por
Adicionar a sua resposta
Robert G será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 32
Últimos 30 dias: 164
Ao todo: 3,640
