Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Perguntas Visualizar todos
Drive will not spin or accept/eject disc's, insert triggers power-on
I have a fat 40gb Playstation 3 that I was tasked with fixing.
The problem I cant seem to figure out (aside from replacing the drive) is:
  • The disc drive does not engage when a disc is inserted.
    • The Playstation does however, turn on if it is off when I slide a disc in (hitting the trigger switches)
  • If I put a disc in the drive (while the drive is disassembled) and hold down all the trigger's, the drive does not spin up and the laser does not turn on.
    • since it doesn't seem to get a signal about a disc in the drive, I cant eject. just the double beep comes from the playstation.
So I am left wondering what is up with this. Should I just replace the whole drive?
I don't have a second working drive that I can use to test if it is something coming from the motherboard..
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Benjamin Shefte it does sound like it all comes back to the drive. I would go ahead and replace it. Use this guide PlayStation 3 Blu-ray Disc Drive Replacement - iFixit Repair Guide If your drive is a original style of Blu-ray drive, KEM-400, use this guide PlayStation 3 Blu-Ray Drive Replacement - iFixit Repair Guide
Imagem de PlayStation 3 Blu-ray Disc Drive
Guia
Nível de dificuldade:
Moderada
15 minutes - 1 hour
Imagem de PlayStation 3 Blu-Ray Drive
Guia
Moderada
45 minutes - 1 hour
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Benjamin Shefte será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 24
