Ir para o conteúdo principal
Informações de reparo, desmontagem e resolução de problemas do Steam Deck com tela LCD, um console de jogo portátil fabricado pela Valve, lançado em 25 de fevereiro de 2022. Identificado pelo número de modelo 1010.
B button catching and getting stuck on shell
Has anyone come up with a solution to fix this? I thought maybe replacing the buttons might work, but the only part you can buy right now is the button membrane, which doesn't help. The only solutions i've seen currently is to either put a piece of tape in between the button and shell so the button doesn't catch, or to open up the steam deck and sand down the inside of the b button hole so it's nice and smooth. Anyone had any luck with the sanding?
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
1 resposta
Here is the link to the teardown if that is the route you want to take: https://www.ifixit.com/News/57101/steam-...
I haven't done it on the Steam Deck but have for other devices. It is also worth a shot to make sure when putting it back together, that it is lining up properly.
-Warren-
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Conner C será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 32
Ao todo: 4,209
