Ir para o conteúdo principal
O Mac Pro de início de 2009 — também conhecido como Mac Pro 4,1 — introduziu a arquitetura Nehalem da Intel à linha de computadores desktop profissionais da Apple em março de 2009. O Mac Pro 5,1 utilizou o mesmo design interno, mas recebeu novas atualizações de CPU em 2010 e 2012.
Is this CPU compatible?
I know about delidding the CPUs for the 4,1 (which I have) but will the X5675 on this page work?
Here it says it will work,
But do I have to find a delidded version?
@oldturkey03
Esta é uma boa pergunta?
Pontuação 2
12 comentários
@beanman56 probably be easier that to match the heatsink like this http://forum.netkas.org/index.php/topic,... but will cost you way more
por Compartilhar
Ughh.. could I just get a heat sink from a 2012?
por Compartilhar
@beanman56 probably not. To easy :-) Just shim it. Couple of washers and you'll be set.
por Compartilhar
so put washers on the screws so it's not putting too much pressure on the CPU (because it's made for a delidded CPU)when tightening??
por Compartilhar
@oldturkey03 - so put washers on the screws so it's not putting too much pressure on the CPU (because it's made for a delidded CPU)when tightening??
por Compartilhar
Exibir mais 7 comentários
Adicionar um comentário
1 resposta
Solução escolhida
Hello @beanman56
Apologies in advance but I am not Oldturkey03
But I do know that the cpu will work in a Mac Pro 4,1 BUT ONLY IF YOU FLASH IT TO 5,1 I cannot stress this enough,in order for this to work you need to do it
As for de-liding people really like to charge a premium for delided cpus so I would order a deliding vise and to it manually
I have a 5,1 and it has the Intel Xeon X5675 so just a little more assurance for you :-)
Hopefully this answers your question
Esta resposta foi útil?
Pontuação 2
2 comentários:
Uhh, I'm not that confident in being able to do it.
Thanks for trying.
por Compartilhar
No worries:-)
por Compartilhar
Adicionar a sua resposta
Ben Capehart será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 21
Ao todo: 592
