xbox with a error code 07
i have a og xbox with a error code 07 red and green blinking light both fans are loud DVD drive wont open its says your xbox requires service 07
Esta é uma boa pergunta?
https://www.youtube.com/watch?v=VSrRaA6M...
This is the fix.
Any more problems ask in the comments of this answer.
Esta resposta foi útil?
From what I have seen, possible causes for this error are a failed hard drive, insufficient voltage to the hard drive, failed/loose IDE cable, incorrect jumper settings on the drives, or even a failed DVD drive in one case.
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 1,863
4 comentários
Is this an original Xbox?
por Andrew S
@andrewsawesome Yes, og means original.
por NR26
Can you disassemble the Xbox and upload a picture of the circuit board? Adicionar imagens a uma pergunta já existente
por Andrew S
@andrewsawesome I'm not the person that asked this question.
por NR26
