I can’t remove screws from home button
I’m having trouble removing the home button screws, I’ve tried two different screwdrivers and they’re not budging. please help
Esta é uma boa pergunta?
Two two screws are just Philips #000. Assuming you're using the correct screwdriver and you haven't stripped the screws, a good way to get a tight screw loosened is to actually tighten it a tiny bit first. This "breaks" the seal that the screw may have with its matching thread, making it much easier to loosen and back ou.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 46
