Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
Hinges how to replace
HI
I have followed a HowTo on tightening the screws to correct a loose screen that flops back. Unfortunately, even after removing the screen and tightening the screws I still have the problem.
My question is if I was to replace the screen do the hinges come with it and would this be a possible fix? albeit a rather costly solution.
My PC is a MacBook Air 13 early 2015 model. 8GB ram and 256SSD.
Regards,
Allan.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
I think you're throwing the baby out with the bathwater needlessly!
Once you get the display physically off you can replace one hinge to see where that leads you MacBook Air 13" (Mid 2012-2017) Display LVDS Cable That might offer enough stiffness and it's not as difficult as replacing the other side. For reference take a look at what's involved to take the cover glass off in a MacBook Pro MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement which is a similar process to disconnect the camera cable.
The other option which I think is a bit extreme is replacing the display assembly MacBook Air 13" (Mid 2013-2017) Display Assembly and the hinges are part of the assembly.
For either the process is the same MacBook Air 13" Early 2015 Display Assembly Replacement
Imagem de Replace a display compatible with the model A1466 Mid 2013 to 2017 MacBook Air 13" laptop. Includes the 1440 x 900 LCD 13.3" screen, aluminum case and camera. Part #661-7475, 661-02397, 661-02505.
Produto
$314.99
Imagem de Replace a display LVDS cable with a damaged connector or torn cable compatible with a model A1466 13" MacBook Air from mid 2012 to 2017.
Produto
$19.99
Imagem de MacBook Pro 13" Unibody Mid 2010 Front Display Glass
Guia
Nível de dificuldade:
Muito difícil
4 hours
Imagem de MacBook Air 13" Early 2015 Display Assembly
Guia
Moderado
45 minutes - 2 hours
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks for the info, Dan.
After looking at the removing the glass option I've decided my screen looseness is not all that bad. :).
I have had the screen off which was simple enough. However as for the glass option I don't have all the equipment need to do it, and not to keen to use the heat gun.
Regards
Allan
por
@knightal - Changing out the LVDS cable (and its hinge) takes me about a 1/2 hour, replacing the camera cable (and its hinge) alone takes me a good two hours.
I still think replacing the LVDS cable is a good 1/2 step and not too costly.
The camera cable needs the heat gun treatment.
por
Known issue Display "falls back after 100°" is there a fix?
Pontuação 0
Adicionar a sua resposta
Allan Mearns será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 31
Ao todo: 739
